Cost of rendering exterior wall
28 Dec 2013
Hi , i need to repair cracked render to the lower exterior of my house.
Approximate area - 11.3 meter x 43cm
How much would this cost roughly?
Easy enough to do it myself ?
You haven't got any replies, because it's impossible to give quotes in this sort of situation; you need to get a few people in to quote for you.
Post a picture first, so we can at least see the problem though. If you do it yourself, it'll partially depend on how handy you are, and what you're skills with a trowel are like. And depending on the thickness you apply, then you'd need maybe a couple of bags of cement, and 5 or6 bags of shard sand mixed at 1:4. (but it might need more, or less. And depending on the cracks, it may be easier to widen them a bit, use a tube of 2 part resin, and then paint it.
