We're in west Wales and want to remove a 1950's style tiled fireplace with a living-flame type gas fire and replace it with a gas 'wood-burner' style stove.
The new gas fire will sit in a prefabricated steel Stove-Chamber which means the hole left after the original fireplace is removed and a new register plate fitted the flue is unlined.
Once the stove-chamber is in place the chimney breast will need re-plastering up to the picture rail. The new hearth fitted the new 'gas stove'
fitted and gas checked.
It's not a big job and probably be finished in a day, 2 at most.
I desperately need some advice as to the cost I should expect.
The only materials we are not supplying should be a bit of mortar & plaster which as it's an old house will be lime based to patch it up.
Many thanks to anyone who can offer any opinion.
