My sister has a Heatrae Sadia megaflo hot water tank with two immersion heaters for her hot water. Heating is separate, by storage heaters (no gas supply to flats). She has had some problems, and an electrician has been called a couple of times. Last time, he told her how to reset the thermostat if it tripped. However, there are a couple of things I'd like advice on, please.
From my reading so far, I think that the lower immersion heater is the overnight timed one, and the upper is the boost one - is this always the case?
The thermostats are "COTHERM type: TSE T115". There is a little red plastic switch labelled SAFETY which the electrician told her to "pop out". However, using a small screwdriver to press this switch does not release it out again. Should it, in fact, be pushed in?
I ask both questions because I took the cover off the lower stat and the switch is level with the blue surround, whereas the top one (which the electrician adjusted last time) is depressed. However, the boost currently works and the main water heating does not.
Finally, if this happens again, is it most likely to be a dodgy stat, or will the whole element need replacing?
Sorry for the long post, thanks in advance for any advice.
