Bath waste installed without rubber seal in place.
Leaked.
Council plumber No 2 couldnt see problem but cut cut off pipe near the tee in the process and attempted to seal the stump with boss white.
Leaked.
Council plumber No 3 couldnt see problem but wrapped some ptfe tape round the thread just in case.
Leaking.
Boiler condensate has to flow uphill to reach waste pipe.
Exit hole not made good and snow gets in under the bath
Tenant in dispair
Its all solvent welded so Im going to renew the lot with a
new trap and pipe straight out though the wall and the condensate kept separate until outside (where the pipes all fall to a hopper)
I need means of coupling two potentially different types of overfow pipe WITHOUT solvent weld
Ive seen these
https://m.ebay.co.uk/itm/McALPINE-U...056041?hash=item3a8278c529:g:FgIAAOSwVFlULRUA
Tenant cannot afford to pay for repairs(should not have to really)but dreads what Council Plumber No 4 will do.
I have some cheap 22mm push fit similar to the black 15mm in the photo.Before I have to wrestle the grab rings back
off ,any guesses to would this seal just enough for the boiler condensate.
Leaked.
Leaked.
Leaking.
Tenant in dispair
Ive seen these
