Looking around insulation seconds I have seen this: https://www.secondsandco.co.uk/product-page/105-110mm-1-2x2-4m-foil-tissue-kooltherm-sheet
Foil on one side, tissue on the other. I can't even find this particular product online does anyone know what it is, if it has a special application, and where it would/would not be suitable?
My other query was about PIR board sold for cavity part-fill applications. Is this any different from what you'd use in full-fill... seems to just be foil on both sides?
The 3 areas I'm putting my order together for are:
I would prefer to buy the same stuff for roof and floor if possible, for the wall I'd like to go with 1.2x.45m boards and just build the stud around them.
I figure I want foil anywhere it is exposed to air or possible damp... what else is important?
- 100/120mm insulation between joists in a suspended wooden floor. So the base will be open to the air
- 75mm insulation in a stud wall against an external solid timber wall. I'm leaning towards solid-fill i.e. pressed against the wall with an interior VCL under the plasterboard.
- 100/120mm insulation warm roof i.e. a solid layer of PIR on top of a VCL
