Hi all, well the kitchen is nearly in. The guy I go to do it has done a cracking job up to yet, got to come back tomorrow to finish off.
1: He has jointed the worktops but used PVA rather than a coloured sealent. You can just about see the joins. Can I use ColorFill now the joint has been done?
2: Unfortunatley he fitted one of the wall cabinets the wrong way and you can see four screw holes at the end, the one that should have gone there had no screw holes visible on either end. Swapping them is not an option as one has been cut around the soil pipe stack. Would you fill the holes, if so what with? I know you can get little push in covers but I think this would look a bit cheap, any ideas?
Thanks in advance
Thanks in advance
