Hello all
After my first attempt of float & set (many moons ago - with help
), the bathroom on the floor above has now been completed and I can close in the soil pipe in its internal cavity in the room below (see pic)
I had used edge beads for the float & set and had positioned them so I could put the large piece of wood back in its original position to cover the gap.
Upon reflection, I think this will look v untidy, so I would like to reconsider and put a piece of 12.5mm wallboard in its place and skim right over the lot (inc the edge beads). I'd secure the wallboard with plasterboard adhesive.
It has been about 1 month since the bathroom was finished and not sign of any leaks on the soil pipe connections.
One of my thoughts is cracking - but if I scrim well with three layers maybe slightly crossing, I'm hoping it would be ok.
I'm not expecting to need to go back in and if I had to pick off the board & re-do/skim, wouldn't be the end of the world.
Is there a problem with this? My other nag is building regs perhaps?
Your views appreciated as always.
