crack in newly plastered ceiling
2 Jan 2006
Buckinghamshire
My kitchen ceiling has just been skimmed flat. Prob is that most of the ceiling had a grey colour plaster already on it. A small area was just the original ceiling board. But between the two of these was a large crack and a small hole. The plasterer filled made good then skimmed over entire ceiling flat.
It is now aprrox a week later I have not painted it yet but there is a fine hairline crack following almost the same pattern as the original bigger one.
Is there anything I can do to prevent this crack getting any wider. If you can make head or tails of this good luck.
Thanks :roll:
Is the crack in a straight line?
If so its probably down to the fact that either the plasterer hasnt used joint tape...or...there is a lot of movement in the ceiling itself.
You could try raking the crack out first then filling it....but im not sure that it will work, you could line the ceiling...or use a product called evencil...its a thick flexible emulsion made by polycell...personally I dont like the bumpy finish it leaves..but it may sort out your problem
Hi thanks for replying. It is not a straight crack. I have purchaseed some of the emulsion that you speak of and I will give it a try. Maybe I could just use it on the crack line itself and not the rest of ceiling. :D
Youl have to do the whole ceiling...it will show otherwise..
