- Joined
- 18 Aug 2015
- Messages
- 68
- Reaction score
- 4
- Country
I had wall built and the outside face was then rendered (the inside is not seen and has bushes up against it, so that side was not rendered).
it’s breeze block exterior garden block wall around 4 feet high and around 30 feet long with expansion joints (please see photos) built around 2 years ago.
After about a year it seems to have developed a vertical stepped shaped crack on the outside of the wall.
I think it is breeze block (although not sure) and I dug out the crack and filled it with exterior filler. After 6 months the crack has re appeared so I started again and used Toupret exterior filler to repair the crack.
I also put some filler on the side of the wall which is not rendered, just in case there was a crack and water was getting in on the inside.
Now some 6 months later again the crack has re appeared. A friend said maybe when it was built one of the blocks may have cracked but the builder just rendered over the top of it, although I’m not sure if this is the case.
Can anyone suggest what I can do to stop repair the wall and stop this crack re appearing as this is my 3rd attempt to cure the problem ?
