The dividing wall between our two Bedrooms is approx 12ft long with one
half being breeze block (from top to bottom) then the other half is in brick.
Adjoined to this, on the breeze block wall, there was a cupboard (accessed from the landing). We have had the cupbaord removed. However we now
see that about 18 inches from the floor up there is a crack running about
4ft along the wall in both bedrooms (which is where the cupboard was knocked out on the other side). The Breeze Blocks have/had concrete slabs between them. This is a property built in 1954. I have read that it can be common in Breeze Block for them to crack and also that it is not major/dangerous in internal walls, is that correct? What (if anything) should we do to remedy this?
