Cracked drain.
5 Jul 2007
Bristol
While digging a trench at the front of my property for the gas service to be installed, I discovered a clay pipe (prob 4-5") which i think must be connected to the front drainpipe (the waste & water drains are at the rear of the house) This pipe is encased in concrete, except for the very top which is partially exposed in places, and has a crack running along it.
The house is terraced, so I assume the pipe serves the run off from the front roofs of several properties.
The problem is that as the pipe is encased in concrete I cannot tell the extent of the damage to it, while it is exposed I would like to repair it, but how can i expose enough of the pipe without damaging it as it is encased in concrete!?...
Any suggestions greatfully received. :)
Unless the drain is in a virtual state of imminent collapse,why try and repair it if it,s encased in concrete, unless it,s spewing out when it rains
in which case you will have to dig it out and repair it. Otherwise leave well alone!
Keith.
