We've managed to cause some damage to clay sewer pipes connecting our drains to private drain running across our street. The main private sewer line seems fine but our bit joining onto it has collapsed at the oblique junction (encased in concrete). Due to the concrete, we can't put a flexible coupling on outside of clay pipe to join new pipe section.
Instead, I am thinking we could make a join from inside. I am thinking something like a WC connector would do but hopefully there is something just for the job? Is this a really bad idea? It does mean that the sewer pipe would be narrower for a small section underground.
Another option is to cut a channel in a upvc pipe section and then overlap on this channel making smaller diameter pipe I can squeeze inside clay. Then put a flexible connector on the other side and concrete around it. This may be better than WC connector as it would give less of a narrowing.
And my final option - I could make a butt joint with another clay pipe and then encase it all in concrete.
I guess 'textbook' way is to dig up the oblique junction and replace it with a new section with flexible couplers. I don't really want to go there if there is an easier way though - its probably a job for 3am and likely I would finish knee deep in floaters with another bad memory.
Please help with any thoughts/advise!
