I had a crack on the plaster next to a large window. I removed the plaster to find out the cause and it looks like there has been a very small movement over the years to create a crack in a couple of bricks (please see Pic 2). Should I put some mortar around the lintel, some mesh and then re-plaster?
Another question on the outside of the concrete boot lintel. A small piece of concrete has come off showing part of a rusted metal rod (please see Pic 3 & 4. Could I put a touch of Hammerite around the metal and once dry cover it with a mix of 3:1 sand/cement? How can I prevent the mortar from falling off?
Thank you.
Thank you.
