- Joined
- 9 Jan 2017
- Messages
- 11
- Reaction score
- 0
- Country
If the boiler wasn't pumping the heat round the system, then it would overheat, and cycle down, then when the heat had dissipated, it would switch itself back on again. So does it run normally, or switch on and off. What are the time periods that you use it for (how many hours a day).
Yeah it doesn't "feel" like its on that much!
I've heard it come on three times since getting home at 1800 and each time was for about five minutes with around another five minutes of boiler burn (I assume to top up the thermal store?).
It's not set to the clock (I think that is broken as it does not respond to it or rotate). It's set off the hall stat and advanced if it gets cold and manually shut off. At night it's turned down and rarely comes on!
