Hi there, we had the floor up earlier in the year to have some electrics done and discovered that at some point in the past a when central heating was installed the floorboards had been replaced with MDF/Chipboard. (See pic)
The trouble we have is once back down the areas where the board is are very very creaky. It is screwed in 100% tightly but the boards seem to depress between the joists and creak against their adjacent boards (they are a very tight fit when put back in)
Originally i thought that maybe i'd just take them out. My plan is to take a sander to the edges to give the boards a little wiggle room and then resit them and put talcum powder into the edges to stop the rub. Does this sound like a reasonable plan?
But as i'll be having them up would it be worth replacing them with something stronger. I don't think they should be depressing as much as they are between the joists. I don't think i could just replace with new floorboards due to the pipe runs (Probably why the central heating fitter went with the boards in the first place)
When i pull the carpet up again it's going to be a one time thing so any other options would be greatly received.
