Hi Guys,
Just moved in to a new house (built 2003), which was built by barratts, so obviously the quality isn't very good.
The floor at the bottom of the bed and the floor adjacent in the small bedroom creak like hell, to the point it disturbs our new born!
I've lifted the newly laid carpet, and the flooring is 2' x 7' plywood, and the creaky board goes under the wall from the big bedroom in to the small bedroom. You can also see a slight dip in to floor if you compare it to the skirting.
I bought some huge screws and a pipe/cable finder (so I didn't have any accident), and screwed loads of screws through the ply, in to the joists - this didn't do a thing! I also tried the talcum power trick, but obviously that did nothing as well.
I phoned a well known joiner in my area, who didn't really seem interest and said there was nothing I could do?!
Surely there is an answer to this, as we aren't getting much sleep with the newborn anyway, and the creaky floor is making things worse.
Could I circular saw the boards up, and install loads of extra noggins? Would this actually help? I believe the ply should be 18mm? What size wood would be required for the extra noggins?
I don't suppose there is a lot I can do about the sagging joists?
Any advice would be great, as I may need to DIY this.
Thanks a lot
Thanks a lot
Thanks a lot
Thanks a lot
