There are 2 ways to form external corners without using beads, but it's not easy explaining in words. You can form reveal corners/soffits, using a batten/s (arris sticks), which are temporarily fixed around a window/door opening, ( fixed to the wall face), the reveals/soffits are then rendered, floated and sponged, and left to set. I should also add that everything is scratch coated first (walls, reveals, soffits), then the arris sticks are fixed to the wall face around the reveals.Once the soffits and reveals have set, you then "very carefully" remove the arris sticks/battens.I normally give each stick a "gentle tap" along the edge to make a vertical crack between the edge of the timber batten and the finished rendered reveals. You can now "very carefully" pull out the nails and gently remove the 3 arris sticks/battens around each window/door. This particular method is one i would use if i was going to roughcast a wall,,, using the hard, newly rendered hard edges of the reveals to roughcast to. Make sure, that all the battens/arris sticks are plumb/vertical around each window/door reveal, and level/horizontal across the soffits. The thickness of the render around the windows/doors will depend on the very outside edge of the window frame. Set each arris stick to line up visually with the outside edges of the window frame, plumb/level them up, then fix temporarily ready for the render coat.
You can also roughcast the reveals/soffits by doing it the following way. After scratch coating everything, walls, reveals, soffits, fix the battens in the same way, coat the reveals/soffits very neatly with wet cement, then throw the roughcast chips onto the wet cement, let it set, then carefully remove the battens the same way as was said earlier, you're now ready to roughcast the main areas of wall.
Later, i'll try to explain to you, how to form a "wet returned external rendered/plastered corners" using a straight edges/arris battens, that are "held flat" against the face of the render/plaster, and moved/slid up and away, from one face of each wall corner/reveals, to the other, giving a perfectly finished, 90 degree wet rendered corner, without a corner bead in sight. There's far more work doing it without beading, but it's satisfiying work, and you need to watch it like a hawk, in case someone damages a corner before you've finished it.
Showing someone how to do this is far easier than trying to put it into words, and you learn better too. I'm sure some of the other lads on here will add to this topic as well.
I forgot to say that when you're working around windows etc, be careful not to get any render etc on the glass, or you will definitely scratch the glass windows. Keep the window frame clean too as much as you can. Cover the window cill with a layer of sand to keep it clean.
Right, back to the football.
