Hi all, got a problem with a cross water concealed shower mixer. Unit is 18 months old and has never adjusted properly.
installation is in a modern flat with an electric mains pressure hot water cylinder. Pressure to cylinder is assumed to be balanced because hot water is produced via flat plate heat exchanger ( comments welcome)
shower valve does not adjust for temperature. Cartridge has been replaced but no change. The unit is of the type where if hot and cold are incorrectly plumbed the cartridge can be rotated 180 deg to correct. This doesn't solve the problem (when reversed unit allows cold water only through)
With cartridge removed flow of both hot and cold water into body is ok.
