Cut flex outlet into marble tile...?
19 May 2005
Sussex
I need to cut a flex outlet into a corner of 12 inch marble tile. They're hard as fook - what's the best way to cut a square out, assuming I use one corner and only have to make two cuts? Or would it be easier to knock the whole tile out and refit a precut replacement? Drill a million little holes?...
Any tips much appreciated cheers!.
I'd go for a small angle grinder witha diamond disc. wet the tile continuosly as you cut.
If that fails, smash out the ruined tile and replace! :D
A-holes! Diamond cuttings disks are pricy on screwfix. Look like £20 plus... how easy is it to keep a straight cut, and what about the end of the cut!!!?
Cheers :D
