Pretty much as the title states, I want to install a new window in the loft room on the gable end wall. Do i need planning permission? building regs? Can the work be done from the inside or is it a scaffold job?
You will be required to follow building regs; you will need to get BC to inspect the lintel & cavity closers before the window is installed (they may get nosey about that loft conversion as well if it’s not existing!) & you may even need PP as you are altering the outside appearance of the building but check with your local planning dept.
Afraid you will need outside access to cut the hole in the external brickwork & finish off the lintel/window installation – depending on the size of the hole you probably wont need to prop. I had 2 x 1200mm windows cut in a 1st floor gable without propping (a pig if you need to that high up) & not a single brick moved.
