Cutting chipboard with jigsaw
19 Mar 2006
Hertfordshire
Hi everyone.
I need some basic advice please.
I have been cutting down some laminate chipboard wood for shelving in a bathroom unit and I have not been happy wiht the finished cut.
Althoug the cut is a straight line across the board the actual cut looks slightly curved / angled when you look down it. It looks to me as though the blade is curving slightly during the cutting process. It almost looks live a bevel cut.
Do you think this is a sympton of trying to force the jigsaw across the wood rather then letting the jigsaw go at its own pace?
Does varyng the speed of the blade /pendulam action help?
Yes, you must let the blade do the cutting at it own pace otherwise the blade got no choice but to force out as the jig-saw is pacing too fast.
A jigsaw is not the best tool for cutting an even straight or perpenidular cut - the blade will wander however lightly you push it.
You should use a circular saw, or as its just a shelf, a hand saw and then finish the edge.
Or a router will reduce melamine edge chipping
new blade helps. Bu the thing is, you have to push down on a jig saw because that is how it works, if you dont push down the saw will jump up and down and the blade stay still (ok, not that still) , and it will not cut. But agree its not the right tool for strait lines
Thanks for the advice guys, I think I sussed what the main problem was.
I was clamping a staight bit of metal to the wood to use as a guide for the jigsaw. This mean't that the jigsaw had no room for minor movement and therefore mean't that the blade had to do the moving instead.
I reverted to free hand in the end, took it very slowly and finished with a result I was happy with.
