Hi guys,
I have an odd scenario where I gutted all but one of the rooms in my upstairs, which included some new stud walls, all new door frames and much more. In hind sight I should have thought of this earlier, but because I hadn't tackled the one bedroom and we had family comign to stay with us so I was in a rush, I left the uprights and header of the door frame into the untouched bedroom too deep, I.e. deeper than the wall protruding into the bedroom, with the intention being to cut it back later.
I'm now at that stage, where the room is done and replastered and the frame needs to be cut back aproximates 12mm. I'm not as worried about the frame as a circular saw and hand saw for the corners should do the job.
What worries me is the stopper, which was nailed and glued in place. I'll need to cut this back a similar amount while it's in place. Any suggestions on how best to go about this. Guessing that a circular saw with the blade set exactly the thickness of the stopper would work where the saw can run, but I'll have the corners and bottom to cut some other way?
Thanks in advance.
Thanks in advance.
