Cutting down concrete gravel boards - I'm an idiot
22 Dec 2006
Warwickshire
I'm in the process of installing a fence using slotted concrete posts, standard fence panels, and a 12in concrete gravel board.
I've installed the posts at each end, and have just realised that I've made a miscalculation. My final cut-down panel will need to be 13.5 cm wide :oops: (I was expecting it to be much wider)
One option is to cut each panel down by 42cm, which will result in 4 equally sized panels, and will look acceptable.
I'm not concerned about cutting the wooden panels down, as I've done that loads in the past, but I've never cut a concrete gravel board down.
I figure a few diamond cutting discs on my small angle grinder will do the job, but I'm concerned about exposing the steel reinforced "re-bar". If I expose this don't I run the risk of it rusting and the boards falling apart? What are people's experiences of cutting concrete gravel boards down?
How far do the reinforcements run? If I cut 21cm off each end maybe I'll miss it!?
Or should I just bite the bullet and make up a stupid 13.5 cm panel. I suppose I'd still need to cut a board down, but at least it'd only be one.
I have cut them and 10-15 years later they are fine
You will need to have a slitting disc as well to cut the steel.
If worried, dab the cut ends with something like bitumen or scrap paint
