Cutting-in darker than rolled paint
5 Feb 2007
Lincolnshire
I have a problem whereby the brushed cutting-in I have done has dried noticeably darker than the paint I have rolled onto the wall, leaving an obvious dark band running around the top of the wall. I have been using B&Q Colours magnolia matt paint. I cut in one wall at a time and rolled as far onto the wet(ish) cut-in band as possible. Any ideas?
Thanks very much.
R
The cut in is significantly thicker than the rolled walls, another coat on the walls should fix it.
