Cutting Laminate Worktop
16 Nov 2006
Hull
Hi I'm fitting a standard b&q laminated kitchen worktop and I need to cut the worktop to size. Could someone tell me what tool is best to use to prevent the laminate from splintering when I cut it. Should I use a jigsaw with a special blade or hand saw etc. cheers
Circular saw, fine tooth saw blade. work from front to rear - BUT turn the worktop over so that you are cutting from the underside. Jigsaws work, but in inexperienced hands can produce somewhat wavy lkines (especially with manky DIY jig saws)
Scrit
