Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
OK, so what tools do you have already that can take off a slither? i.e., not a jigsaw.
A mitre saw would be what I'd go for. You can clamp a scrap of wood to the fence, right up to the blade, then you put the workpiece up to that clamped piece and the amount removed will be the kerf (thickness) of the blade.
Even smaller amounts can be taken off by pressing the workpiece up against the stationary blade, then raise the blade and come back down with it on, you'll remove about 0.5mm each time with that technique. It depends on the play in the saw's bearings, etc.
