I have some small wall tiles to replace and a few need cutting. The problem is the edges are not straight by design. So, if I cut the tile with a straight edge it will look silly. How do I cut it wavy to match the other edges?
I'll post a picture later. It's the end of a run where the last tile meets the end of the wall - probably need a quarter tile at most. I could cut it straight but the cut edge would be exposed at the wall end.
