Sorry if this is buried in the WIKI - I know it deals with CH drain downs but this is just about hot water.
Basically, need to do some pipework on the hot and cold water in the bathroom [which is where the cylinder is]
Unfortunately, there is no isolation in the current pipework between cylinder pipe and hw feeds.
My intention is
Turn off HW and CH [which is off anyhow in this weather]
Turn of mains cock
Drain cold storage tank by opening taps
Drain HW in cylinder by opening taps
Am I then right in thinking that there will be no water still coming out of the top of the cylinder [HW] when I do the pipework?
I am assuming that the base of the cylinder will still have some water in but I am only concerned that there is no more to come out the top while I am doing the work.
System is fully-pumped vented with a back boiler feeding into cylinder [if that makes sense]
I am concerned that I may need to drain the whole system to make sure!!
I have drained the CH before but not the HW draw-off.
Also, I want to fit isolating valves to the HW feed so I can isolate it at source if I ever need to again. I assume these need to be full valves so as not to restrict flow??
Thanks and sorry for the idiotic question....
My intention is
Turn of mains cock
