Hi all, first post from a newbie so apologies if I'm not quite up to speed with forum-use.
I'm a competent and experienced DIYer and I'm sure this should be simple, but I don't want to guess....
I need to replace an ACL HTS2 cylinder stat, which has three wires soldered into it - from the factory, I assume. I haven't bought a replacement yet, but I realize that a new stat from any maker will probably have three terminals labelled C, 1 and 2. Only trouble is, the terminals inside the old stat aren't labelled, so I don't know which is which.
Looking inside the junction box one wire obviously goes to the 3-way motorized valve, but the other two disappear into the wall and I can't trace them. I've looked at the installation instructions from Drayton, Honeywell and Danfoss but can't find the info.
Thanks if someone can help.
