Hi, I'd be grateful for ANY advice please!
We've not been in our house long and have had the system drained once or twice to replace leaky radiator valves. We had air in the system and the pump made a noise until the air worked its way out. We've also had one or two rads off to decorate.
Here's the technical bit:
Ideal Classic LXFF & FF Fanned Flue Gas Boiler controlled by a Dafoss FP715 control panel.
Problem:
Both heating and hotwater are timed to work twice a day but our boiler fires up throughout the day regardless. It has been firing up more frequently recently - it goes off and on all day long now and our water pump seems to be permantly on. Its like the system is trying to keep our hot water hot all day long. Is this right?
A friend as the same boiler but it only works during the 'timed' periods. Have we got a faulty Dafoss controller? Or is it our pump that is knackered? I am assuming that the boiler is only doing what the controller tells it to do...so guess it must be the controller but I'm not an expert!
I don't know if this is connected but our wall thermostat in the hallway 'clicks' at 10c - this doesn't seem right either. Is it connected to our problem?
Hope this is enough detail! Sorry if it is too much!
Many thanks, Nic
Problem:
Many thanks, Nic
