Hi
Can anyone tell me if this joist needs replacing it is one of a pair of joists doubled up.
Directly above there is the stud wall of the bathroom also the joist is one of three which will support the bath running in parallel.
The damage which was caused by poorly sealed bath over some years only seems to be at the top and bottom although not had a close look as floor still has to come up when new bathroom is fitted.
Previous bathroom fitter fitted a batten or what I'd call a botch!! Managed to take some pics through a gap near the bath waste.
Sorry can't seem to make pictures larger.
Does it need replacing or can it be sistered with a new joist?
Or can a third joist be inserted as close as possible to it to give extra support?
Sorry can't seem to make pictures larger, from what I can see it looks like maybe only 20mm at top and 10mm at bottom is water damaged but that leaves 170mm possibly ok from a 200mm depth. I know the top and bottom areas are the most critical for stress loading. The joist/s don't move under stress only the floor boards move due to the damage. The overall span is approx. 3.5m.
