Hi.
My 3in1 detector failed to warm me about a ring main cable in the wall. When I put the screw in the raw plug the point of the screw pierced the cable and tripped the RCD.
The cable runs up the wall and into the loft space which I have access too. So running a new cable from the socket and joining it in the loft space is not too much of an issue.
What is an acceptable method of joining the cable? My house was built in 2000 in red and black and is currently up to the regs of that era, so I dont want to bodge it and void that status. Plus I want it safe. I understand that a ring main has a breaker of 32amp based on the ring using two cables. But any single point of the ring main must support 20 amps. So the joining method must be rated for 20amps or above. Is this correct?
Secondly. Am I allowed to do this or is it a job for a sparky? I'm a pretty confident DIY person.
Many thanks.
Many thanks.
