Hi all, have been reading the numerous posts relating to rising/penetrating damp and havent found the answer to my problem so thought id put it to you all direct! The house is a 1900 end terrace with solid walls.
When i purchased the property i was told by the surveyor that there was damp present. I employed a contractor to carry out the chemical damp course installation. When carrying out the works he hacked of the existing plaster (soft sand based mix) to varying heights from 500mm to 1200mm. Once complete he rendered the walls with a sand/retarder/cement mix before skimming with multifinish. He recommended to allow the walls 9 months to dry out before final decoration. 12 months on and their is still moisture present on the wall. The moisture is only visiable in those area where he took the plaster off to 500-600mm and it appears in horizontal sections for 200-300mm above his new plasterwork.
I spoke to him today and he has said that the old plaster is affected by salts and was drawing moisture through the wall and therefore needs hacking off and replacing. Apparently if i simply remove the affected area and re-render (he was strongly against limelite) then the problem will cease. However if the old plaster was affected shouldnt all of my wall with the existing plaster show damp signs not just the areas immediate from where he has worked.
Really i believe that as i employed him to remedy my damp situation he should off hacked off enough to sufficently eradicate the problem. Although if the hacking off will cure the issue i will probably do this myself to avoid the hastle of him returning. But i am worried that if i remove the 300mm section affected the damp will just appear above that section???
He also went down the lines that the damp could be penetrating through the walls due to mortar issues/spalling, although surely this would be visiable in other areas?
