Does all the plasterboard need to be replaced following a damp issue due to leaking shower in en-suite?
There is a cupboard adjoining which houses the unvented hot water cylinder.
This had damp which was showing in the cupboard but is obviously worse on the reverse of the plaster board - the sides in the en-suite and bedroom. Pictures below.
If this plaster can be left in place this would obviously save having to get a plumber to remove the water cylinder!
Can I treat the wall using another way instead? I have used vinegar to clean the surface damp so far.
Maybe I need somebody to have a look as the damp came through underneath the floor joist along the floorboards but which trade do I need?
Further details:
En-suite shower room which has been leaking inside the wall where the built in shower mixer had been leaking.
I think this has been on-going for at least 6-8 months but did not notice until damp penetrated into the adjoining bedroom! My house is a bungalow so most of the water has been going down into the foundations.
I have removed the shower and capped the water supply, will be getting someone in to re-board, plaster, fit new shower etc.
I had removed the plaster in the en-suite but realised there was also damp inside the cavity of the bedroom wall which I have removed too. The last picture below shows what is was like before I removed most of the plasterboard.
Thanks in anticipation of any advice.
Sandeep
Further details:
Sandeep
