Hi
We are going through some building work and upon taking the Lino up in our kitchen we found the floor to be very wet along the outside wall.
When we had the adjacent kitchen wall removed we found the cavity to be filled with what looks like concrete, as high as a couple of courses above the dpc.
Using a hammer and chisel I managed to clear the cavity of the little section of wall that was left next to the wall that was removed, but obviously couldn't go around the corner to clear the remaining wall.
I am pretty certain the cavity is filled above the dpc along the wall in question.
Could this cause the floor to be as damp as it is?
If so who do I contact to rectify this problem?
We have just had the walls dot and dabbed and are due the kitchen to be fitted in a weeks time.
Should the new dot and dab be okay?
Should we hold off on getting the kitchen fitted?
We did get a damp company out a couple of years ago as we were getting mould on this wall, they told us the dpc was shot and they wanted to inject it.
Although we were warned by others to stay away from the injected dpc as it's not solving the issue and it was probably condensation as it's in the kitchen so never acted on it.
Below I have added a photo of the cavity before I cleared it and of the wall in question to give you an idea of where I am talking about.
The wet floor is not very obvious in the photos but the bottom of the lino was very wet in this area.
Sorry for the long post, any advice will be greatly appreciated as we don't want to fit a new kitchen and have it destroyed by damp.
