- Joined
- 8 Jun 2021
- Messages
- 13
- Reaction score
- 0
- Country
Clean it off with one of these type of products.
Really? another good tip and a lot cheaper than the things I linked to. I wonder how that works.Tomato ketchup will also kill it, and help clean it off.
Hi thanks ...pics of roof/parapet attached..no sign of wetness above the growth. Moreover, the growth appears to be thick at bottom i..e more at the door side and then travelling to the top part...Not an expert, but that suggests to me, that you may have a roof leakage, and water is getting into the cavity. Can you post some photos of that area, of what appears might be, a flat roof above?
Many thanks..asked builder to come out and he suggested three holes across the brickwork to let air flow ..Same as Harry says, it looks like the start of alagae or lichen. Clean it off with one of these type of products.
I would also have thought you might need weep holes across the door to let any water that gets into the cavity drain out.
Seems no leak in the parapet above...also no dampness in the wall above...algae seems to to grow bottom to upside.Is there a leaking joint in that parapet trim above?
Is it a blocked weep hole?
Thanks for your reply...yes the growth seems to be following from bottom to upside i.e. from more near the door lintel and then less towards the brickwork to roof..there were tiles used above the soldier course.. not sure if these act as DPC..OP,
The growth seems to start at the thick bed - the bed with what looks like tile inserts above the soldier course.
Perhaps the inserts were meant to be a kind of DPC?
No signs of weep holes or even blocked weep holes - so no evidence of a cavity tray on the outside face of the brickwork.
Pics of where the roof abuts the parapet - & pics of the parapet cappings would help.
Any signs of damp penetration in this area inside the property?
FWIW: There's a rusting edge of perhaps an angle iron that needs grinding to steel & re-painting.
Removing the growth with a dry scrubbing brush will work.
Apologies but I looked at the joint again and it seems fine..the color is bit rusted over time but nothing seems unusual on the joint...This joint is the problem, you can see it staining vertically.
Looks like an insufficient drip (overhang). No bottle of Heinze is going to help.
