damp patch on ceiling
4 Oct 2006
Cambridgeshire
Hello
I had a damp patch on the ceiling in my daughter's bedroom. The damage is now repaired and it is dry but when painted with matt white, the yellow stain quickly shows through. My Dad was told by a plumber that you can paint gloss over stains first and then matt and that will stop it coming through. Any thoughts on this? I am reluctant to do it in case the matt will not then take.
Saz
hi yep that works although I would use an oil base undercoat as matt seems to stick to it better. For a proper finish I use a stain blocker instead, either in a spray form or out of the tin. Both dry quicker than the oil based solution and are availiable at all good stockists. Zinser and Damp Seal are both popular makes.
Id say the same...i dunno why people say gloss though...emulsion will have a job stickying to fresh gloss...its a bit of an old wifes tale..
However...oil based undercoat, as DSD says will do the business...just make sure you give it a couple of days to dry properly
Been posted a few days now and no-one has said "PVA it Mate" :shock:
Message must be getting through at last :wink:
