Property: brick mid terrace, cement rendered..
I injected the exterior wall of this mid terrace property with Dry Zone over 2 years ago. Internal plaster was hacked off, treated with salt solution and then Thistle Dry-Coat(cement based) was used, then a finish coat of multi finish.
The wall was left well over a year before ANY paint was applied. Only got round to painting it say 6 months ago. Paint was soft sheen.
Last few weeks noticed some bubbling paint patches, the artic weather hasn't helped
They're isolated patches and quite high up, the worse you can clearly see as I've sanded off the bubbling paint, the wall doesn't even feel cold. On the other side on this wall is next door! Only just noticed the other two patches today. This wall is north facing and is at risk from damp as it takes a long time to dry out being.
The exterior wall is free from any cracks or defects that would allow water to penetrate. I'm convinced it's brick salts that's the problem, salt problems persist throughout these houses and it seems almost impossible to treat without removing the affected bricks.
Luckily this is the one area of the house at this level that hasn't been dry lined, reason being it's tricky to do being on the stairs. So, I need advice on a solution. My thoughts....
1. Suck it and see temporary solution....Sand off the flakey paint, apply some damp seal and paint over.
2. Board over or clad the affected area. It's only a rental so never going to be a show home. At the moment the plaster is rock solid. My only worry with this solution is that over time, will the plaster turn to mush, thus loosening any fixing used to fix the cladding...?
3. Hack off back to brick up to a level then dry line, either with treated timbers or with plaster membranes. I would use some kind of bead or dado rail to hide the join between the plaster above and the dry lining below. This being the worst case scenario.
View media item 19652
