Hi all, I'm a FTB buying a 1930s semi. The mortgage provider requested I instruct a Specialist to investigate after the mortgage valuation/survey found rising damp at the property. I've received a report back from the Specialist who I made sure was wholly independent and not a contractor and he believes a chemical damp proof course is required at the property.
I'm unsure if a DPC should be the first course of action as from reading more about this issue, I suspect in my case the damp is caused mainly by the laying of a tarmac driveway. This has caused the external ground level outside to be raised, and breach the height of the original blue engineering bricks/damp proof course. There are 2 layers of blue bricks, the tarmac only breaches half of the first layer. At the front of the house, the tarmac is also partly blocking the sub floor vents.
To be fair, the specialist did point out the high external ground level was a major contributory factor so I don't understand the reason a DPC is required as a first course of action. Surely it would make more sense to lower the ground level approximately 150 mm below the DPC as he is also recomending, and then monitor the situation before attempting costly remedial DPC that is probably not required.
I don't know what to do, as I know I have condition in my mortgage offer stating I need to carry out any remedial work as advised and there is also a retention in place to make sure I do. I'm conflicted as I don't personally believe the damp problem is serious, as the ground floor has mainly oldish wallpaper throughout and it does not look like the wallpaper is peeling off at all and the skirting boards look in good condition. It's definitely not like the seller has tried to hide the damp by skimming or painting over the problem. Damp is only visible in a small corner of the porch where plaster has peeled off which alerted the mortgage valuer.
I would love to know what others think. How much would it cost to lower the tarmac level ? Is it something I can do myself ? or does it require special machinery ? or should I just get the DPC done and forget about lowering the driveay at all. In theory will the DPC eliminate any damp completely, even though the problem will still exist with the high external ground level.
Thanx in advance everyone.
