I recently moved into a house and am confused over a damp issue.
Due to only recently moving in and it being an old house which has been extended I'm trying to establish the construction methods. The bedroom is cavity wall.
In the main bedroom there is a chimney breast in one corner which is showing signs of damp as the wallpaper is bubbling, I have removed this and given it a wipe over. It doesn't feel very damp but the top foot or so is clearly is a different colour.
The room does have a damp feel and one morning I woke up and the double glazed windows were completely wet with condensation.
The chimney has been removed below roof level and not capped as the clay liner can be seen under the loft insulation. There are no signs of water entering the loft.
I'm struggling to find whether the bottom is vented as its behind a lot of cupboards/panelling which will eventually be removed with the refurb. A part of the chimney breast is visible in the garage below the bedroom with no signs of damp but it appears to have has a hole created in side? I'm still unsure why this would be and will try and upload some pics.
I suppose I want to know:
1. Does the exposed chimney liner need to be capped/insulated?
2. If not, do I cover with insulation as found or leave it breathe?
3. Is the amount of condensation and damp feel in room directly linked to uncapped chimney breast in loft?
Chimney does run from garage below through to loft
There is probably no insulation between garage and room above(will be rectified)
Thanks in advance
Thanks in advance
