HI I had cavity wall insulation (rock wool) removed due to damp on internal walls - all along base of the hall -which worsened when it rained . My surveyor advised the retro fittred cavity wall insultation was responsible as outside wall was sited to suffer wind driven rain. I bought the house with the problem and contacted the installers to remove under the CIGA guarantee. They agreed to remove as a good will gesture stating the insulation was not cause of damp but the wind driven rain and porous render would have been too much for the insulation and broke it down. Though inspector later advised me the wool that had been used was no longer used as it holds water, I was just happy just to get it removed. A month ago the team took it out. After a couple of dry weeks damp got much better we had rain and it all came back. I rang them they came up and looked with a camera advised me some wool was still remaining and they come to take it out. . Though the areas of damp did not relate to areas of wool left when i watched them removing it. I thought my damp problems were over and watched the lower walls all dry out again.i usea little water gadget though i know they are not considered very accurate I thought just by the pattern of readings decreasing show it is drying out. All good till we had raing again and walls looking damp again and all readings back up high. Has anyone had insulation removed and faced these issues ? does the damp go i am trying to understand if I should be contacting the insulation company again or exploring other options and considering my surveyor/home buyers report and the supporing damp survey i also obtained had the wrong cause of the damp ? Help anyone ?
