Did someone mention dry lining ?? there should be no plasterboard in whatever shape or form on the ground floor of a property this old.
Why is this?
Are you saying that in a property this old that damp is unavoidable?
how do you feel about increasing the ventilation now?
http://www.british-gypsum.com/pdf/PDS-022-01%20Gyproc%20ThermaLine%20PLUS.pdf
Above is the pdf file on Gyproc thermaline plus. You say you have "vapour checked" your walls with it when in fact it sounds like you have just "isolated" the damp problem which the pdf file says "you must not do" There's also some scant info on not installing it whilst you have condensation issues.
You can download the "white book" with more info from the Gyproc website.
From what i understand, this is just a thermal insulation board and has no "anti-damp properties.
Have the installers fitted a seperate membrane at all ? And how was the gyproc installed ...?
P.S You definately need ventilation !!!! and no further work should be carried out until you have altered the high ground.....
@mac391
re"Thermaline plus". Not sure what you understand by anti-damp properties but polystyrene is considered impervious to moisture under normal circumstances.
I recall reading research that stated that after 30 days total immersion in water , an expanded polystyrene panel had absorbed 0.2% of its total weight of water.
Ssound pretty good to me on the damp-proof front. Only weak point being the joins.
