Damp
30 Sep 2008
Cleveland
I've got a damp patch in the hallway of my house, extends maybe 30cm maximum from the floor, when I say damp i mean the paint has started to flake off in a couple of places.
Over the weekend I knocked out a brick directly behind the offending area to add an airbrick, anyhow, I've not got airflow through the cavity.
When I removed the brick loads of dirt/rubble poured out, must be at least 4 courses of bricks high with dirt, I've started clearing it out but its hard going.
Just wondering if this dirt is likely to be my cause of the damp? I looked down the cavity with a torch and a mirror and notice along the top of all this dirt the bricks seem to have a tide mark of salt where the dirt came up to.
If the cavity is full of debbris you may well get damp ingress on the inside as moisture may be able to bridge the cavity.
CortinaV8
Very likely that the debris is the cause. Was the debris also damp? Is this an external wall?
Had this on my house. Must have taken about 20 rubble sacks worth of crap out of the cavity. Whole wall was sodden. Since the dig out the problem has not returned.
HRH
