(system is vaillant 428 boiler + 3 port valve, cylinder stat, room stat & grundfoss pump, plus Danfoss FP715 programmer)
I had some suspicions about the operation of my Danfoss ATC cylinder stat and was thinking of replacing it ... (turning the stat up or down seemed to have little difference on the temp of the water)…
Anyway I took the cover off just to see how it was wired … and how easy it would be to replace…
It has 3 wires coming in to it … blue, brown & green/yellow
• The green yellow earth wire is connected to terminal 1 (co)
• The blue wire is connected to terminal 2 (nc)
• The brown wire is connected to terminal 3 (no)
I was somewhat surprised that nothing (including the green yellow wire) was connected to earth…
Does this sound ok … or not?
BTW: Should the stat be directly controlling the 3 port valve ie should the motor be opening closing the valve immediately the stat clicks on/off … or does the stat feed into something else which decides when to operate the 3 port valve?
Thanks for any help
Thanks for any help
