Hello
Apologies if this is in the wrong section.
Currently we have a central heating and normal hot water tank system with a Danfoss FP715Si programmer box.
Next week we are getting the Hive smart thermostat system which means I would like to replace the programmer with the new Hive programmer.
Is this a very straightforward replacement? Will the Hive box fit exactly where the old one was and will the wiring be compatible?
We also currently have a ordinary thermostat on the wall, which I assume is connected to the programmer, so when installing the new Hive box is it just a case of leaving the old thermostat not connected to anything?
Thank you.
Thank you.
