danfoss fp720
14 Jul 2022
danfoss fp720 programmer does not follow the timings i set eg 5.30 to 6 am after 6 the little symbol for hot water is still there and if you change the cylinder stat the boiler fires
I tried resetting the danfoss nothing changed
Are there any led’s on this and do they go out? If yes, it could be a failed motorised valve.
the l 3 way valve works the cylinder stat works the programmer does what I said it looks exactly as I should the heating and water function
Not on a new one, I would get it replaced by your installer or Danfoss. Only other thing might be if it takes batteries and they’re depleted.
i can replace it odd that modern batteries last a short time my last programer batteries lasted over 20 years
