Dangers of wall drilling Electrics Gas Water
21 Feb 2021
Is there are any way of testing or finding out if you're about to drill into a water pipe, gas pipe or the electrics?
UK,
22 Jul 2016
Common sense helps, as a socket should have it's feed running vertically or horizontally.
You should be able to gauge by where the cables come into the backbox although it's far from 100%
Water pipes tend not to run in walls and at a guess gas pipes also?
21 Feb 2021
But the sockets feed, the cables can be anywhere in the wall.
21 Feb 2021
Isn't there a machine that detects pipes or cables?
30 Dec 2018
There is a metal detectors and a live cable detectors, some do both, but they are not absolute.
