My shower is fitted in such a manner that it cant really be removed from the wall without some extensive work. But since its fitment about 8 months ago, i now have to set the temp gauge noticeably higher to get the same water temprature as i could get from a lower setting a few months ago.
To me this points to limescale on the heating elements which is stopping all the heat from transferring to the water effectively. I do live in a hard water area.
So is there any way of de-scaling the inside of it without removing it from the wall?
I was thinking of turning the water supply to the house off and draining the entire system via a downstairs tap. Then disconnecting the water feed pipe to the shower, filling it with some sort of de-scaling product and letting that sit in the shower for about 5 minutes before turning the shower ON and letting it all fly out.
Would this technically work? Or am i looking at potentially causing some damage to the shower?
Thanks for your help.
