De-sludgeing central heating system
18 Sep 2007
Durham
Can you get stuff that you can squirt into your radiators to get rid of sludge ? should you use a corgi man for this or could you do it legaly yourself ?
fernox f3 and hyperflush are my favorite. leave in for about 4 weeks.
read FAQ for lots of info on this
What number gets rid of sludge ?
1) Thermostatic Radiator Valves sticking shut.
2 )How to balance a CH system
3 ) Motorised Valve Failure
4) Central Heating Guide.
5) How to flush a heating system with mains water.
6) Refilling a sealed system
7) Repressurising the Pressure Vessel
8 ) Radiator Problems.
9) Bleeding a ch pump
10) Water is coming out of boiler's "pipe"
11) Boiler kettling
12) Temporarily removing a radiator
13) Can I get a CORGI engineer to "sign off" an installation?
14) Changing a cistern float valve
15) Replacing wc float valve
16) Bleeding Radiators
17) Air lock in TAP WATER pipes
18 ) F & e tank overflowing
19) How do I know if the pump is working correctly?
20) System pumping over
21) Central heating noises
22) Replacing a CH pump
23) Toilet flushing problems
24) Blocked Cold Feed
26) Why Does My Basin Leak?
27) Burying Copper Pipes
28 ) Central Heating Protection
29) Removing Cast Iron Stack
30) Hot Water tank Overflowing
31) Boiler Pressure Problems
32) Draining A CH System
33) How do I unblock a sink or basin?
34) What size boiler do I need to replace my old one?
35) Changing from lead to copper pipe
36) Immersion Heaters - DANGER FROM BOILING WATER IN LOFT TANK
37) Combis - Combination Boilers - Do I want one?
38 ) How much gas am I using?
39) Why Is My Hot Water Not Hot Enough?
40) How to fill a Worcester Bosch combi
41) Should I have a Flueless Fire installed?
42) DANGEROUS BOILERS
43) UNVENTED CYLINDERS
44) UNVENTED CYLINDERS--Should I have one?
45) Is DIY GAS LEGAL?
46) How Do I Size My Radiators?
47 ) Pumping Over
48 ) Boiler Manuals
mic
like i said: read FAQ
We have 2 FAQ's on this site & 1 FAQ does not have anything about de sludging central heating systems in it, the FAQ is for help using the forum.
Perhaps you are meaning the Wiki & this page which says nowt about adding stuff.
Or perhaps this guide about rads yet still no idea on how to add additives.
Although if you google the additives they give instructions on the site for it.
:D
doing the job with weak chemicals that can stay in for up to 4 weeks will make a minor difference so i wouldn't call it de sludging, it's more like rinsing the system through. if your system works fine and you want to give it a little freshen up then you can get a tube of fernox restorer with an injection kit so you can inject it straight in to a rad.
5, 8, 24, and 28 all deal with cleaning the system.
maybe i should have added:
read: "announcements" at top of first forum page
as well as
"wiki" section
to put the cleaner in:
buy cleaner
bring it to header tank
open container
poor in tank
if you want to put it in a rad:
isolate rad
empty rad
poor liquid in
and re-connect rad to system
if putting in the header tank don't just pour it in it'll be useless as the cleaner all stays in the tank and makes skin form on top of water, no cleaner gets in the system
if pouring in to the tank, tie the ball valve up, drain enough water to empty the tank and a bit more, pour cleaner in then let ball valve fill back up
I would also add, bale out any mud from the F&E tank first and sponge it clean, no point in washing that muck down into your rads.
When you are doing your initial draining (to let the chemical in), consider if your drain-cocks are convenient and adequate as you will need to do a complete drain and flush in a few weeks after you have loosened the sludge.
If not, you can get a radiator valve with drain-cock attached, or add a conveniently-placed full-bore cock that will accept a hosepipe. Preferably put it on a return pipe which will be a bit cooler, it seems to me this makes valve last longer. Get new washers for any drain cocks as you may find the old one is perished.
If you can afford an extra £100 and do basic DIY plumbing, fit a Magnaclean as well. I guarantee you will be amazed and delighted at how much black sediment it traps, and this will prevent future black material accumulating into new blockages.
screetch just 1 tube ? (3 bedroom house ) everything works ok, my service guy just checks the boiler feels the rads and says its all good £50 please lol
