de-soldering - unsuccessfully
30 Mar 2015
I was recently trying to repair a leak on 15mm copper pipe. I was sweating off 2 elbows. One came off pretty quickly. I saw the solder run, twisetd the fitting and it came away. Another elbow did not shift at all. I heat it continuously and with breaks. No joy. I also tried pasting some flux on it but that didn't shift it either.
In the end, I cut the pipe before the fitting, which caused me additional agro...
Any ideas on what might have been causing this and how I get around it in the future?
Any water in the pipe?
ah, it's possible that this section had some water sitting it it. Hadn't thought about that.
How empty/dry does it need to be and how do I solve that? I did run te taps but I h=guess this pipe sits at a lower level than the taps.
Also, I didn't notice any steam from the pipe when I was heating it...
Pretty dry, if only damp then the flame will clear it. But more than a few drops will kill the heat.
Although water is the usual cause it is Not unusual for fittings to not come off it may have been really tight before even being initially soldered
in that situation, do you cut the pipe instead? I guess the pipe isn't always accessible to a cutter i.e. you don't have the clearance around it.
yep , when there isnt any room get a big hacksaw blade wrap abit of duct tape on it to hold and the do the best to cut through it with small strokes obviously as pros we will have multitools / reciprocating saws but have used just a blade many a time
I have a Makita multi cutter and a Makita Recip saw. Wouldn’t they rip the pipe apart though? Let alone a clean finish to get a fitting on to.
